REGISTRATION OVER 3CX TRUNK
Discussion in 'iOS' started by black6, Mar 3, 2013.
  1. black6
    Nov 26, 2012
    9
    Hi All,
    We are having trouble getting the 3CX V3 to register over the 3CX tunnel app on the iphone. The older 3CX IOS phone registered without issue, but since we have upgraded to V3 we can't register over the tunnel when out of office. Anyone had this issue?
    Regards,
  2. StefanW
    Jun 2, 2009
    1,222
    93
    Hy back6,
    it has answered before, the new 3CXPhone 3 does not work with the app and will not make use of this product (now and later).
    The Tunnel was a nice try but unfo is something apple not clusters as an voip application and therefore no endless background mode..
  3. black6
    Nov 26, 2012
    9
    Hi StefanW,
    OK, so how do we connect the 3CX V3 remotely for our of office connections? I use this a lot over my 3G connection and I know many of our clients will do the same.
    Regards,
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    If your particular network scenario does not allow you to connect 3CX Phone for iPhone/Android remotely without the use of the 3CX Tunnel Protocol, then you are left with 2 options:
    • 3CX Phone for Android with 3CX Tunnel Protocol (built-in)
    • Get your phone to first establish a VPN to your main office before registering with 3CX Phone
    Having said this, I would first make sure that the Firewall Checker provides a clean result from the 3CX Phone System machine before giving up on using a remote 3CX Phone in "Direct" mode.
    Regards
  5. black6
    Nov 26, 2012
    9
    Hi Kevin,
    If we connect our iphones over our Cisco VPN with the Bria APP then all is well. We could also connect the old 3CX softphone client over the 3CX tunnel APP, its just the new V3 we are having trouble with when using the 3CX V3 and tunnel APP together. If I have understood correctly you are saying that the V3 does not work with the 3CX tunnel APP?
    regards,
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,545
    298
    It seems this is the case indeed - also lots of comments about this on the Release Comments (Blog).
  7. complex1
    complex1 Active Member
    Jan 25, 2010
    813
    46
    The new 3CXPhone 3 works well over WiFi AND 3G, at least over here in the Netherlands.
    We don’t use the tunnel app anymore because it won’t work with the new 3CXPhone 3.
  8. Borreltje
    Mar 5, 2013
    Did you have to make any special settings? I an trying to get my iphone5 to connect over 3G in the netherlands, but so far no luck.
    my provider is KPN, it used to work with version 1.1.5 with tunnel, but with version 3 it is not working.
    If I first connect my VPN connection it works, but is it possible to get it working without VPN?
    regards, Bor
  9. complex1
    Jan 25, 2010
    813
    46
    Hi Bor,
    I am using KPN also as my internet provider, so that’s not the problem.
    The problem is that almost all providers blocked port 5060 to discourage the use of VoIP calls over there network.
    There are several solutions to make calls via the internet: use of VPN, use of Tunnel or, and this is what I did, change the standard SIP port 5060 into something else.
    If you are going for this solution, you have to change the SIP port in 3CX and all extensions. Don't forget the router.
  10. Borreltje
    Mar 5, 2013
    Aha, thanks for the advise, I'm gonna try that.
    regards, Bor
  11. Borreltje
    Mar 5, 2013
    Tried changing from port 5060 to 5062, and the iphones worked great over 3G.
    Only one thing, my Etech VPPH01 voip phone can not register when 3cx is on 5062.
    I did change the port in the etech setup, but the phone did not register, odd thing is, when I set 3CX back to port 5060,
    but left the etech on 5062, the phone did register!!???
    so now 3CX is running on port 5060, but the phone is not! but is working?
    any help woould be great.
  12. complex1
    Jan 25, 2010
    813
    46
    Goto SIP Protocol Settings in your phone and set
    Register port: 5062
    SIP Proxy: <IP address or FQDN>:5062
    Domain: <IP address or FQDN>:5062
    This should do.
  13. Borreltje
    Mar 5, 2013
    Great! that works, thanks for the advice!
