Registration Problems
Discussion in '3CX Phone System - General' started by absolut, Feb 22, 2008.
  1. absolut
    Feb 22, 2008
    6
    Hi there,
    i m new to voip technology .. so take it easy on me :)
    i installed a 3CX server at work and added some computers (with X-Lite) and everything worked perfectly
    today i was trying to register my home X-Lite to the work 3CX server with no success .. (registration timed-out)
    can anyone help me regarding the configuration of the 3CX and the X-Lite for an external extension ..
    any suggestion or link or idea would be very much appreciated :)
    Thanks in advance,
    Hisham
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    It shouldn't be a problem. Have you opened the ports on your firewall?
  3. absolut
    Feb 22, 2008
    6
    well i checked the work router, which is a DLink .. and the firewall and filter settings are still set to default .. no changes.
    the PC firewalls are turned off .. on both computers
    which ports should i enable and on which router or computer
    thanks in advance
    Hisham
  4. matthijsolislagers
    140
    On the server network:
    -Forward port 5060 UDP to the ip of the router
    -Forward port 9000-9015 UDP to the ip of the router
    -Open these ports as well on the server computer (if firewall turned on)
    On the client network.
    -Make sure outgoing traffic isn't blocked.
  5. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    also check windows firewall
    cheers
  6. absolut
    Feb 22, 2008
    6
    1- if my PC firewall is set to off .. will the traffic of ports 5060 & 9000-9015 be forwarded to the 3CX?
    or should i enable the firewall and change the settings of each port?
    2- how will the 3CX know the exact IP address of the external user (the one not on the server LAN)?
    both systems r using the same STUN server .. but how will they identify each other?
    thanks in advance,
    Hisham
  7. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    The external user is logging itself in in your 3CX. You filled out the WAN IP adress in the external extension with the right ID and password, 3CX (when the right ports are open) will accept that registration because the credentials match.
    So it is the extension which is contacting 3CX.
    Do not only open firewall ports by rules but also NAT port forwarding otherwise it won't work or just work with problems.
  8. absolut
    Feb 22, 2008
    6
    Well i managed to register the external extension .. i wasnt using the External IP address of the 3CX server (my bad)
    on the other hand, i m getting these errors when performing the Firewall Test
    The external extension was able to call the internal one but with one way audio
    I have DLink routers on both ends (DI624 & DI524)
    I think i managed to port forward to the IP address of the 3CX server but i think the problem is caused by the PAT (Port Address Translation) running on the routers(i think it can be seen from the warnings above). I ve run a small emulator and it said that i m running behing a full cone NAT with PAT enabled.
    I ve searched in the DLink menu for the PAT but with no success ..
    So any idea?
    Is there a difference between the firewall port forwading the NAT port forwarding? Please explain
    Thanks,
    Hisham
  9. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Since we are talking about an external extension, your best bet would be to use the 3CX Client and configure the Tunnel.
    This requires only port 5090 TCP to be open on the firewall router.
    You should be up and running in 10 minutes max.
    The manual has all the tunnel info you need.
  10. landfiets
    Jul 17, 2007
    243
    Sorry but I don't agree. 3CX should be able together with right configuring to just let people use hardware phones externally.
    When you say that you should use the voip client with tunnel, you give yourself immed. a limitation for what 3CX is able to.
    I think you should try to figure out how to make it work without going to use the voipclient. I've never heard of a PBX which was forcing you to only use your own addit. software. Yeah I know one........SKYPE.
  11. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It lets. The only question is how to configure that hardware properly.
  12. landfiets
    Jul 17, 2007
    243
    Exactly !! I agree with Archie, but it is a bit hard I believe and normally an external extension must be able to login 3CX without a tunnel. I run several extensions here without any problem, all external
  13. archie
    3CX Support
    Aug 18, 2006
    1,299
    It all depends on firwall/NAT device you have. Tunnel allows to narrow firewall/NAT issues to single port.
  14. William400
    Aug 21, 2006
    1,005
    #14 William400, Mar 3, 2008
  15. absolut
    Feb 22, 2008
    6
    Well after testing so many settings on the firewall of my DLinks .. i came to a conclusion that the DLink DI524 does not support static port mapping (i have attached a print screen of my firewall rules .. please check and let me know what do you think)
    Using these settings .. when i run the Firewall Test in the 3CX i get the warning (10) "Port is open, but port number has been changed. In many cases, this will present a problem and cause one way audio or no inbound calls".
    i only managed to call from the external extension with one way audio and couldnt generate an inbound call
    Thanks all for you Help,
    Hisham
  16. William400
    Aug 21, 2006
    1,005
    These look good to me but you are missing STUN 3478 UDP.
    If this does not work and the firewall checker reports errors, your best best is to change router.
  17. absolut
    Feb 22, 2008
    6
    Yeah true .. in these settings i didnt add the STUN 3478 UDP port
    In previous tests, i added this port and as i said, managed to call from an external extension with one way audio.
    If someone has managed to make it work using DLinks, please let me know
    Otherwise i m thinking of getting some LinkSys routers and test again
    *Edit: i m behind a double NATted connection .. my WAN is: 10.40.xx.xx! is this might be the problem?
    because i read somewhere that if i m NATted from my provider i cant set up Servers and it just wont work
    Regards,
    Hisham
  18. William400
    Aug 21, 2006
    1,005
    NAT can be a headache in itself.
    Double NAT i would avoid totally. Get a static public IP from your ISP.
