16-Oct-2013 14:46:36.705 Leg L:48.2[Line:10000>>0030210DestNumber] is terminated: Cause: 403 Forbidden/INVITE from sip.provider.ip:5060
16-Oct-2013 14:46:36.705 [CM503020]: Call(C:48): Normal call termination. Call originator: Extn:491. Reason: Forbidden
16-Oct-2013 14:46:36.705 L:48.1[Extn] failed to reach Line:10000>>0030210DestNumber, reason Forbidden
16-Oct-2013 14:46:36.705 Call to T:Line:10000>>0030210DestNumber@[Dev:sip:[email protected]:5060] from L:48.1[Extn] failed, cause: Cause: 403 Forbidden/INVITE from sip.provider.ip:5060
16-Oct-2013 14:46:36.704 [CM503003]: Call(C:48): Call to <sip:[email protected]:5060> has failed; Cause: 403 Forbidden/INVITE from sip.provider.ip:5060
16-Oct-2013 14:46:36.250 [CM503025]: Call(C:48): Calling T:Line:10000>>0030210DestNumber@[Dev:sip:[email protected]:5060] for L:48.1[Extn]
16-Oct-2013 14:46:35.999 [CM503027]: Call(C:48): From: Extn:491 ("Caller Name" <sip:491@localPBXIp:5060>) to T:Line:10000>>0030210DestNumber@[Dev:sip:[email protected]:5060]
16-Oct-2013 14:46:35.999 [CM503004]: Call(C:48): Route 1: from L:48.1[Extn] to T:Line:10000>>0030210DestNumber@[Dev:sip:[email protected]:5060]
16-Oct-2013 14:46:35.999 Line limit check: Current # of calls for line Lc:10000(@providerName[<sip:[email protected]:5060>]) is 0; limit is 5
16-Oct-2013 14:46:35.999 Call(C:48): Call from Extn:491 to 0030210DestNumber matches outbound rule 'International Phone call Rule '
16-Oct-2013 14:46:35.997 [CM503001]: Call(C:48): Incoming call from Extn:491 to <sip:0030210DestNumber@localPBXIp:5060>
jpillow said:@ Leejor They actually have two different accounts it looks like his problem is setting up his outbound rules to pick which account to used on which calls and his international calls may be blocked....
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
