Registration to Voip Provider Failing
Discussion in '3CX Phone System - General' started by blang008, Jan 23, 2016.
  1. blang008
    Oct 27, 2015
    16
    Trying to get 3cx registered with an untested voip provider. Issue is that they require a tenant number in front of the SIP username for authorization. However, they want just the telephone number to show in the To/From sip header. Below is what i'm sending and is an example of what they want to see. The attached file ff2 is what i am sending. Everything here is correct except that in the highlighted area, I need to send 260010- in front of the telephone number. The file provider example is how they would like it to look. Any help would be appreciated.
  2. blang008
    Oct 27, 2015
    16
    Issue resolved. Had to use 3way authentication.
  3. jmooo
    Mar 11, 2015
    18
    Hello
    I'm wondering what exactly you put in the 3cx "3-way authentication" field?
    thanks
    and did voip.ms become a stable service with your 3cx??
  4. Anonymous
    Anonymous Guest
    Voip.ms has been rock-solid for us. Both as a main SIP trunk as well as resold trunks. They are one of the few that have a built out reseller portal.
