Registration unsuccessful
Discussion in 'Android' started by mdoman, Feb 19, 2011.
  1. mdoman
    Feb 19, 2011
    I studied forum for Android and I doidn't find very simple explanation how to put all required data to register using voipcheap. Please forgive me but I don't know android and 3CX settings well and I can't register. Could everyone confirm what I do wrong... I use ver 1.2.9 and and I try to register as follows:
    - profile name: any
    - user: my username in voipchep service
    - pass: my password
    - internal server: empty
    - external server: sip.voipcheap.com
    - stun server: empty or stun3.3cx.com or stun.voipcheap.com (all the time unsuccessully)
    - proxy: sip.voipcheap.com
    - port: 5060
    - dtmf method: any method is unsuccessul
    I don't know whether it is possible to register using this service by 3G or wi-fi
    Thank you for help.
  2. mdoman
    Feb 19, 2011
    I forgot to mention about device: htc desire z
  3. jlag
    Feb 14, 2011
    34
    I have always left the proxy and the port blank for my registrations.
    Also, if you want to use cellular data network, you have to edit the profile Integration section to turn on 3G.
    I have gotten this to work with 3CX PBX, VOIPVOIP, FreePBX, Asterisk and Vonage SoftPhone.
  4. jlag
    Feb 14, 2011
    34
    SORRY, proxy blank, PORT 5060 (default).
  5. leejor
    10,868
    304
    Normally, with most VoIP providers, the username field will contain your phone number, if they assigned you one. You will need to have a STUN server datafilled in the majority of cases.
    I would try getting it to work with wi-fi first, then, if successful, move onto 3G and see if you can get that working. As I've discovered, some 3G won't work.
  6. minestrone70
    Mar 1, 2011
    Connected
    User= your user name
    ID= your user name
    puth both External server and Proxy to: sip.voipcheap.com
