Registration
Discussion in '3CX Phone System - General' started by janderkan, Oct 3, 2007.
  1. janderkan
    Oct 3, 2007
    Using Kirk Wireless 600 server and snom on free edition.
    Snom registering fine kirk system not.
    I tried changing credentials but no luck.
    Is there a way to see what data is coming from Kirk.
    Is it ID or password that fails?
    17:12:45.015 AuthMgr::eek:nAuthFailure [CM101000] Registration request from sip:101@192.168.0.3 failed. Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    17:12:45.015 AuthMgr::requestCredential [CM001005] Message SipReq: REGISTER 192.168.0.3 tid=-F7122AE3 cseq=REGISTER contact=101@192.168.0.245:16400 / 64 from(wire) failed authentication!
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    For the logs you just posted ID or password not correct.... all i can say from there, make sure ID and password are the same(i know this is obvious). :|
    Not much i can say about that
    Cheers
