Reinstall new version / can't call outside
Discussion in '3CX Phone System - General' started by wilco, May 13, 2008.
  1. wilco
    Nov 12, 2007
    36
    i have install te last version again to try a little bit more.
    but the incomming call is working but outgoing is not working.
    can i try somthing to test it
    info
    ________________________
    username : 31418700000
    pass : (uw wachtwoord)
    display name : 0418700000
    autorisation username : wilco000000
    sip domain : solcon.nl
    sip realm : solcon.nl
    sip listen port: 5060
    proxyserveradres: sip.solcon.nl
    proxyserverpoort: 5060
    registrationserveradres: sip.solcon.nl
    registrationserverport: 5060
    codecs : G729a, G711a law, G723
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Please place an outbound call and post the server status results so we can see what your server is doing.
  3. wilco
    Nov 12, 2007
    36
    22:35:02.578 Call::Terminate [CM503008]: Call(3): Call is terminated
    22:35:02.562 Call::RouteFailed [CM503014]: Call(3): Attempt to reach "041865****"[sip:041865****@192.168.20.100] failed. Reason: No Answer
    22:35:02.562 CallLeg::eek:nFailure [CM503003]: Call(3): Call to sip:041865****@sip.solcon.nl:5060 has failed; Cause: 408 Request Timeout; internal
    22:34:30.343 MediaServerReporting::SetRemoteParty [MS210002] C:3.2:Offer provided. Connection(transcoding mode): 87.195.51.213:9004(9005)
    22:34:30.140 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(3): Calling: VoIPline:10000@[Dev:sip:3141878****@sip.solcon.nl:5060]
    22:34:30.125 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to "0418653***"[sip:0418653***@192.168.20.100]
    22:34:30.125 MediaServerReporting::SetRemoteParty [MS210000] C:3.1:Offer received. RTP connection: 192.168.20.3:16452(16453)
    22:34:30.125 CallLeg::setRemoteSdp Remote SDP is set for legC:3.1
    22:34:30.125 Extension::printEndpointInfo [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA-921;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Sipura/SPA921-4.1.10(b)] Transport: [sip:192.168.20.100:5060]
    22:34:30.109 CallCtrl::eek:nIncomingCall [CM503001]: Call(3): Incoming call from Ext.100 to "041865****"[sip:041865****@192.168.20.100]
  4. wilco
    Nov 12, 2007
    36
    kick >>> kick
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Try to change codecs priority on Linksys or disable G729 at all.
  6. wisecomputers
    wisecomputers New Member
    Apr 24, 2008
    126
    did you make sure the number is in the accepted source list?
  7. wilco
    Nov 12, 2007
    36
    where can i find that accepted source list?
