Rejected SIP reinvite problem
Discussion in '3CX Phone System - General' started by oneradioboy, Jun 4, 2014.
  1. oneradioboy
    Sep 2, 2009
    11
    I've added Alcazar Networks to my 3CX PBX as a generic sip provider, however I'm experiencing audio loss at 3:30 into a call. Their technical support says that my server is not responding properly to their reinvites and rejects the call on their reinvite. I'm on version 12 SP 3. I've tried ticking the box for Supports Re-Invite on the Advanced tab of the VOIP Provider setup with no luck. Any suggestions?
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Can you give your network topology and replicate the issue use wireshark and post logs of call at the 3.30 mark. Are you using stun?
  3. bardissi
    bardissi Member
    Jan 31, 2012
    318
    You need to go back to the provider to troubleshoot
