Rejecting Calls on Line 2 of 3CX phone
Discussion in 'Windows' started by Liam_rr!, May 23, 2013.
  1. Liam_rr!
    May 23, 2013
    Hey,
    Im using 3CX for Windows (Ver 6.0.20943.0) and having issues rejecting a call that comes in on Line 2. I have created two test accounts (100% functional), i take a call on Line 1, answer it, another call comes in on Line 2, I cant reject the second call (click on reject button) but can answer it. Any bugs relating to this?
    Liam
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Are you using the free version or a licensed version?
  3. jpillow
    Jun 20, 2011
    1,342
    If your using grandstream handsets you may want to check to assure that "auto answer by call info" is selected.
