Relay Fax Software
Discussion in '3CX Phone System - General' started by pogue1000, Aug 17, 2011.
  1. pogue1000
    Jun 1, 2011
    21
    Anyone have any luck using Relayfax to send and recieve faxes?
    For some reason i come with with an error of "Call Interupted" when trying to send.
    The whole faxing and VOIP is a real pain, I bought a grandstream gateway and tried to use an analog fax and that didnt work. Even worked with 3cx support and with that issue and doesnt look very promising.
    I feel like some of these solutions that 3cx offers only work in perfect conditions.
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    We don't offer a sending Fax service, all the information you find here is resources to help. In my opinion Fax should always remain a analog line hooked to a traditional fax machine. (again my personal opinion) no issues and it works. In my experience it is hit and miss with Fax. If you want a sure fire method of sending and receiving fax, use the option I posted, at the end of the day you will be headache free.
    Thanks,
    Nate
