Release FQDN, customer email
Discussion in '3CX Phone System - General' started by business54, May 25, 2017.
  1. business54
    Apr 20, 2016
    71
    12
    I need to release a customers FQDN due to public IP change. The customer does not have record of the email with their logon info. I see their key is still "pending review". Is there a way to resend the registration email?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    Hello @business54
    Why would you want to release a key when a public IP changes? You need to release your key only when you need to change your license or when you need to use a different FQDN.
    If the costumer lost the email with the logon info then they need to contact our sales department and sort it out.
  3. Macaully
    Jun 1, 2017
    What you could do in the mean time if you are not planning on changing the unit as yet is change the public ip to the new one.
    Ensure that you have a backup of the current setup and go to the settings>parameters. This is usually for advance users but if you understand what it is that you need it should be a cake walk. Most likely you have a static public ip so grab the ip of the old setup and type it into the search bar. Once it comes up you can then edit and save the new ip of the customer. Save and test it to see if it did what you desired.
    The fqdn is marked to the unit(mac address etc). However, get customer support to gain back access to the email.
