Solved Reload prompts from command line (linux)
Discussion in '3CX Phone System - General' started by Leonardo Tansini, Nov 10, 2017.
  1. Leonardo Tansini
    Oct 10, 2017
    Hi, looking for a solution to have different prompts during the lunch time, I've written a bash script that change various WAV files prompts according to the day and time I need.
    This is not enough because, I think, there's a permanent prompts cache that isn't affected from the changed WAV till I restart the 3CX system.
    But this requires a quite long time.
    My question is: is there a way to reload changed prompts, to refreshing the cache, from command line so I can do it from directly from my bash script?
    Waiting some replies.
    Thanks in advance.
    #1 Leonardo Tansini, Nov 10, 2017
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Why don't you this with PBX itself ?
  3. Leonardo Tansini
    Oct 10, 2017
    Is there a way in 3cx?
    I can't find it.
  4. sip.bg
    Nov 7, 2016
    704
    219
    You can have inbound routes for in-office-hours and out-of-office-hours and have different prompts.
    If you need more time periods, create a dummy extension and use forwarding exceptions for specific hours to route incoming calls to digital receptionists, queues, where you can have different prompts.
    #4 sip.bg, Nov 10, 2017
  5. Leonardo Tansini
    Oct 10, 2017
    So easy! Thanks sip.bg.
    I didn't know this way.
