Relocate Log Backup Folder
Discussion in 'Ideas' started by Matthewh, Oct 28, 2015.
  1. Matthewh
    Jun 3, 2014
    13
    It would be very useful if we could relocate the backup logs folder off the main operating system drive as this can take a large volume of space and the logging is useful for diagnosing issues or problems so having the backup logs is very handy.
    Regards
    Matt
