- Joined
- Mar 1, 2012
- Messages
- 1
- Reaction score
- 0
Hi to All,
I am new to 3cx, i just install it to my machine and all the local soft phone in my network are working fine but when i try to use it outside of my network it said that the authentication are failed i don't know what to do next. I appreciate your help.
Here is the log from the server.
18:15:55.585 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=b147195a6a419d57 cseq=REGISTER [email protected]:49926 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
18:15:21.998 [CM102001]: Authentication failed for SipReq: REGISTER http://www.litexpress.com.ph:5060 tid=38400045c17ddb34 cseq=REGISTER [email protected]:49925 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
18:14:54.517 [CM102001]: Authentication failed for SipReq: REGISTER litexpress.com.ph:5060 tid=6c3ea401db3ede6e cseq=REGISTER [email protected]:49924 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
18:14:42.535 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server [ V4 199.192.206.228:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 192.168.30.191:5060 UDP target domain=unspecified mFlowKey=0 ]
18:13:55.057 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=e212eb4d1d38d729 cseq=REGISTER [email protected]:49923 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
18:08:59.053 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=a1450a5b857c153f cseq=REGISTER [email protected]:49921 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
18:07:17.889 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=105b3a6a36317852 cseq=REGISTER [email protected]:49920 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
17:55:54.485 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=ad4eee1fa5420831 cseq=REGISTER [email protected]:49919 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
17:55:43.967 [CM504001]: Ext.1201: new contact is registered. Contact(s): [sip:[email protected]:49836;rinstance=459fd194d817cc81/1201]
17:54:42.467 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server [ V4 199.192.206.228:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 192.168.30.191:5060 UDP target domain=unspecified mFlowKey=0 ]
17:47:33.041 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=7e73d15c6360d656 cseq=REGISTER [email protected]:49918 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
17:46:04.500 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=532e614ac5382b29 cseq=REGISTER [email protected]:49917 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
17:45:21.158 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=fb719d0a85734d2c cseq=REGISTER [email protected]:49916 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
17:41:38.837 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=cf036a583f098d2e cseq=REGISTER [email protected]:49915 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
17:39:08.835 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=bf737c1bd83e3e7a cseq=REGISTER [email protected]:49914 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
17:37:40.550 [CM102001]: Authentication failed for SipReq: REGISTER 122.55.12.98:5060 tid=a736df01d36d2639 cseq=REGISTER [email protected]:49913 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
Thanks!
Clark
Thanks!
Clark
