Remote 3CX settings?
Discussion in 'Android' started by jacob tracy, Apr 24, 2013.
  1. jacob tracy
    Apr 24, 2013
    I am trying to get the 3CX app to recognize and connect to my server via the external ip address. The problem is that it wont connect or register. I can connect via internal ip address. I am in desperate need of help as this has to be done ASAP.
    10,367
    228
    You'll have to provide some more details about your 3CX PBX set-up? Do you have other external extensions in use now?
  3. jacob tracy
    Apr 24, 2013
    No, I do not have any in use as of this moment. I am going to try a few different things to see if i can figure out what is going on.
    ie. make sure ports are open and what not
    EDIT: I have checked for an open 5060 port and it is.
  4. kevin
    kevin Member
    Nov 23, 2006
    316
