Remote access to 3CX console*Discussion
Discussion in '3CX Phone System - General' started by leejor, Aug 14, 2010.
  1. leejor
    10,563
    245
    I was playing around with remote access to 3CX. Since local access no longer makes use of a browser and the manual (page 17) shows to use the format http://phone-system/Management or http://phone-system/5481 . " phone-system" being the name of the PC running 3CX. I tried all variations to no avail. First off I found Firefox attempting to add www. and .com., that was correctable in the Firefox settings.
    I ended up trying the old bookmarked http://192.168.XXX.XXX:5481/MainForm.wgx , which, to my surprise, worked just fine.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Re: Remote access to 3CX console
    Local access works fine with a browser.
    phone-system will only work if that is the machine name of your system or if you replace phone-system with the actual IP address. It is probably assumed that you would figure that out.
  3. mcbsys
    mcbsys New Member
    Oct 8, 2008
    176
    14
    Probably more related to how IP resolution is set up in your network (DNS/WINS/NetBIOS). If you want to use the machine name rather than its IP address, and you are inside the firewall, you may need to specify the fully-qualified name, e.g. mypbx.mydomain.local.
  4. leejor
    10,563
    245
    I actually prefer to continue to use the IP address. It's just that because the local machine access no longer opens the browser I began looking at what changes were required to do remote access. None apparently.
