Solved Remote Access to Managment Console
Discussion in '3CX Phone System - General' started by Norman, Sep 20, 2017.
  1. Norman
    Jun 27, 2017
    8
    I have recently installed ver 15.5.
    I went through the configuration, we have all of our phones and extensions all working, the issue I am having is trying to access the management console remotely.
    As 3cx is on a dedicated server during the install I had it listen on ports 80 and 443 for the management console. While connected via remote desktop I can open the management console using the FQDN created during install.
    When I try to access that same FQDN from another computer I get the following error printed in the middle of the page (so I know it is coming from 3cx and not a generic 404 or 403 error:
    "No login allowed to this portal."
    I have looked through the configuration and so far can not find where the management console is blocking it. Can anyone shed some light on what I am missing?
  2. 12494
    12494 Member
    Apr 16, 2010
    311
    31
    Have you verified:
    1. Windows Firewall for specified ports
    2. Port forwarding rules in your LAN firewall
    3. IP blacklist
  3. Norman
    Jun 27, 2017
    8
    All of those have been verified.
    I am able to reach the 3CX management console remotely; but instead of giving the login screen the management console is displaying a message stating that "no login allowed to this portal". The 3CX flavicon is there, the tab renames itself to 3CX. So I know I'm hitting the server; just can't figure out where this message is coming from.
  4. Archie Frederic
    Jan 31, 2017
    72
    try this: "url/management"
  5. 12494
    12494 Member
    Apr 16, 2010
    311
    31
    And you are using the Admin login name, not an extension number for login name?
  6. Brad Cann
    Brad Cann New Member
    May 5, 2017
    111
    16
    isn't the manageent portal on 5001?
    IE:
    https://ip-or-name-of-box:5001
    Don't forget to allow 5001 out from that box in the firewall.
  7. Archie Frederic
    Jan 31, 2017
    72
    This would depend on the port he use during the installation. 5000 and 5001 are just alternative ports, because there is a possibility that ports 443 and 80 would conflict to any other application in the network since it is a common port. But this does not mean you cannot use these ports. you could still use them provided that you can assure that it would never have conflicts in any applications.
    YiannisH_3CX likes this.
  8. Norman
    Jun 27, 2017
    8
    I tried adding /management to the url. still getting the message that "No login allowed to this portal."
    But it works (going to the external URL) from the server 3CX is installed on.
  9. agp
    agp 3CX Team
    Aug 19, 2015
    154
    22
    Hi @Norman ,
    It seems that you are trying to connect to the Webmeeting FQDN of your installation and not the PBX FQDN.
    If the domain you are trying to access remotely is ending in 3CX.NET then that's not the Management Console.
    Since you have access to the dashboard via remote desktop you can easily find your FQDN at the top right section
  10. Norman
    Jun 27, 2017
    8
    now I feel stupid. You are correct, for some reason I was trying to use the webmeeting domain. All is good now.
