remote access to myphone in IIS installation
Discussion in '3CX Phone System - General' started by synapsenetworks.com, Dec 14, 2009.
  1. synapsenetworks.com
    Dec 19, 2008
    I am trying to create a remote (Outside firewall) access to the MyPhone portal on an IIS based PBX. Stupid question :oops: , but what prot should it be on. I can only find reference to Cassini (5481).
  2. manistopit
    Feb 18, 2009
    26
    port 5090 is should be open
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    On Cassinni, myphone runs on port 5000
  4. comresource
    comresource Member
    May 22, 2009
    303
    If you are using IIS it is simply on port 80...BUT if you will be accessing it over the internet I would use 443 to encrypt the login credentials.
