Remote bridged extensions in local PBX
Discussion in '3CX Phone System - General' started by acolville, Jun 18, 2012.
  1. acolville
    Jul 27, 2009
    80
    The manual for V11 states:
    "Extensions on a remote bridged PBX can be configured as agents in queues or as members of
    ring groups on the local PBX."
    I am sure its there somewhere but I cannot find it! In ring group setup only the local extensions are shown.
    Anyone know how to achieve this?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    both sides have a pro/ent license ?
  3. acolville
    Jul 27, 2009
    80
    One site is ENT the others are SBS.
    As far as I am aware, 3CX have changed the policy regarding presence from beta 2 onwards to include it in SBS and upwards.
    There is nothing on the ring group setup page to indicate how to include remote pbx extensions, although there is a greyed out "add external number" on the queue page.
  4. acolville
    Jul 27, 2009
    80
    Anyone worked out how to do this yet?
  5. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Create a fake extension on your master PBX.
    Forward calls in Away status to to remote PBX extension that you desire.
    Put extension in Away status an Login to the queue.
    Now you can add this extension to any ring group or queue and it will work.
  6. acolville
    Jul 27, 2009
    80
    OK, that is how I have been doing this since V8! I thought it might be more integrated, as fake extensions are often criticised in these forums.
    I assume then that it is still not possible to provision BLF's for remote extensions?
