Remote Caller hears a slight echo V14
Discussion in 'Windows' started by petewatterschats, Apr 5, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    I receive a call using the windows softphone
    I use the PC Speakers and Logictech WEb CAM C310
    The microphone in the 3CX Windows client is set to 2-HD WEB CAM C310
    The Speaker is set to Real-Tek High Def Audio
    Echo Cancellation is checked
    On The 3CX Client side the sound is great but on the caller side they here a slight echo
    Any advise would be appreciated
    10,732
    277
    It is not advised to use speakers. Speakerphones are designed to eliminate a lot of the speaker audio to minimise echo, not so much if you use a PC (speakers) and a VoIP application. You are best off using a headset unless there are multiple people that need to hear the audio, in that case mute the mic when it isn't being used.
  3. petewatterschats
    Jan 19, 2016
    151
    Makes sense now that I think about it.
