remote can not hear the voice of local
Discussion in '3CX Phone System - General' started by Thor2008, Dec 15, 2012.
  1. Thor2008
    Mar 28, 2009
    10
    good morning
    i have 3 3cx installation to 3 different customers
    the installation is 3cx 10 mini edition
    every customer report the same problem
    sometime remote can not heart voice of local ( where my customer is in local position)
    i have try to change route ( from Zyxel to Drayteck where Draytec is official 3cx supported)
    i have try to change voip provider ( from eutelia to digitelitalia)
    i have try to change ip phone (from snom to granstream )
    but i have not resolve
    what can i try again ?
    thanks Alberto
    11,073
    323
    Are you talking about a remote extension, having a problem, or, parties being called over a VoIP provider (trunk call)?
    If it is the latter, then it may have something to do with STUN settings, and what you provider requires. If you have a static IP at the PBX location, you may want to explore disabling STUN, and setting your fixed IP in the 3CX settings.
