Remote Desktop trouble
Discussion in 'Windows' started by jcasares, Aug 11, 2010.
  1. jcasares
    Dec 5, 2009
    92
    Since the new version, the one that comes with release 9, I'm having a weird issue. I have the 3CX Assistant and the 3CX phone running at my desktop computer. Whenever I connect through RDP remotely to this computer the 3CX Phone reconfigures itself to use RDP audio channels (even while I have audio redirection disabled). Then when I return to my office the 3CX Phone rings on a "sound card" that isn't available anymore and so I miss the calls until I restart both programs. This started to happen with the new release as I didn't have this problem before. Anybody had this issue as well and know how to workaround it?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,481
    67
    Please tell me which 3CXphone version do you have, as displayed in the About box. The latest version 4.0.13679 contain a fix exactly related to this issue - audio drivers not saved/restored properly. Also, please read this
    http://www.3cx.com/forums/audio-devices-aparently-not-saved-on-3cxphone-exit-16423.html
    Regards
    vali
  3. jcasares
    Dec 5, 2009
    92
    My version is 4.0.13527.0 but I have no new updates reported. Will check again.
    EDIT: the system says is up to date in everything besides Polish prompts that always show like that even while downloaded. :p
  4. Vali_3CX
    Dec 12, 2008
    1,481
    67
    Please check your PM.
    Regards
    vali
