- Joined
- Oct 5, 2011
- Messages
- 16
- Reaction score
- 0
I´m having problems connecting as a remote extension my 3CX Phone for win. I checked "Troubleshooting a Direct Remote Extension", Uncheck Disallow use of extension outside the LAN, Run firewall checker and all is fine and the ports are fine.. the error on the 3CX Phone debug file are:
DX:MP3 Writer initialized
DX:MP3 Encoder initialized
DX:FFDShow not present
Translation file OK
HTTP data provisioning failed
Attempting to connect 187.162.29.XXX
Tunnel got as listening port 62840
Tunnel got as local SIP port 62841
Phone got as local port 62842
Jabra not connected
RTP engine OK
SIP engine OK
Sound mic device OK []
Sound ring device OK []
Sound speaker device OK []
Attempting to start the tunnel
Tunnel required cfg file:C:\Users\AppData\Local\3CX VoIP Phone\3CxVoipPhone.ini
Tunnel logfile output:C:\Users\AppData\Local\3CX VoIP Phone\Logs
Tunnel logging: off
Tunnel bridges created OK
Tunnel started
Tunnel is attempting to connect remote tunnel 123456 [187.162.29.XXx:5090]
Tunnel connection established
Tunnel is attempting to connect remote tunnel 123456 [187.162.29.XXX:5090]
Tunnel has been disconnected by remote end
Tunnel send from phone to PBX: REGISTER
Seems the tunnel conected but few seconds after disconect..
thanks for your help!
Translation file OK
Jabra not connected
RTP engine OK
SIP engine OK
Tunnel logging: off
Tunnel started
