I tried all the suggestions posted so far without any luck. Here is the server log of a failed called. Extension 103 is the originator station on the 3CX system directly and is calling remote extension 101 (PAP2 ATA) located on a different network. Does anyone know what error code 401 - Unauthorized/Invite from 207.164.79.1:55290 means in terms of adapter configuration ?
28-Nov-2012 19:34:40.566 Leg L:7.1[Extn] is terminated: Cause: BYE from PBX
28-Nov-2012 19:34:40.541 [CM503020]: Call(C:7): Normal call termination. Call originator: Extn:103. Reason: Terminated
28-Nov-2012 19:34:40.541 L:7.1[Extn] failed to reach Extn:101, reason Not Acceptable HereReason Unknown
28-Nov-2012 19:34:40.541 Leg L:7.2[Extn] is terminated: Cause: 401 Unauthorized/INVITE from 207.164.79.1:55290
28-Nov-2012 19:34:40.541 Call to T:Extn:101@[Dev:sip:
[email protected]:55290] from L:7.1[Extn] failed, cause: Cause: 401 Unauthorized/INVITE from 207.164.79.1:55290
28-Nov-2012 19:34:40.540 [CM503003]: Call(C:7): Call to <sip:
[email protected]:5060> has failed; Cause: 401 Unauthorized/INVITE from 207.164.79.1:55290
28-Nov-2012 19:34:39.327 [CM503025]: Call(C:7): Calling T:Extn:101@[Dev:sip:
[email protected]:55290] for L:7.1[Extn]
28-Nov-2012 19:34:39.138 [CM503027]: Call(C:7): From: Extn:103 ("PC" <sip:
[email protected]:5060>) to T:Extn:101@[Dev:sip:
28-Nov-2012 19:34:39.138 [CM503004]: Call(C:7): Route 1: from L:7.1[Extn] to T:Extn:101@[Dev:sip:
28-Nov-2012 19:34:39.132 [CM503001]: Call(C:7): Incoming call from Extn:103 to <sip:
28-Nov-2012 19:34:39.123 NAT/ALG check:L:7.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
