Remote Extension on SPA504G
Discussion in 'Windows' started by jeffmcewan, Dec 9, 2009.
  1. jeffmcewan
    Dec 9, 2009
    I can't get my remote extension to connect. The 3CX soft phone connects fine. The SPA504G is setup the same as Kevin explains in the remote video. Packet size: .020, stun enabled, stun server: stun2.3cx.com (same as server), EXT 1 setup with public IP in proxy, user id, p/w, auth enabled, auth pin and resync time set to 300 seconds. The buttons light up and show the extension with a dial tone, but pressing any button gets a fast busy. The phone status shows either Registration State: Failed403 or Registration State: FailedNo Response.
    The firewall should be set correctly with 5060, 5090 and 9000-9049 forwarded using the correct protocols, plus the soft phone works.
    Any ideas?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Are you getting anything during registration in your server activity logs?
  3. leejor
    11,105
    329
    I'm assuming you have this set at the 3CX end. What sort of router/firewall are you behind at the remote end? Is the phone set up to use DHCP or have you assigned it a static IP. If a static IP, double check your IP/ subnet/ gateway settings.
