Solved Remote Extension Presence
Discussion in '3CX Phone System - General' started by belikecopper, Jan 9, 2017.
Tags:
  1. belikecopper
    Dec 20, 2016
    14
    When using the 3CX outside of office, i cannot get presence information on android app or windows client.
    I am using Free PBX license
    I can connect to the PBX to make calls there is just no presence information.
    Do i need to enable BOTH 80 and 443 port forwarding?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,729
    558
    Hello @belikecopper
    that depends on what ports you used to install the PBX. If you used 80 and 443 then 443 must be forwarded for presence. Alternatively it i sport 5001
  3. belikecopper
    Dec 20, 2016
    14
    Thank you for your reply.
    I sorted it out.
    My ports were set to 5000 and 5001
  4. YiannisH_3CX
    May 10, 2016
    7,729
    558
    Glad it worked and thank you for the feedback, i am sure someone will find is useful
