Remote Extension Registers But Cannot Make/Receive Calls
Discussion in '3CX Phone System - General' started by mantalope, May 23, 2011.
  1. mantalope
    Mar 10, 2011
    35
    I have set up a remote extension (3CX iPhone) that registers fine, but when I attempt to make a call, the call gets rejected by 3CX as an unknown user. The log report is below. Any help would be appreciated.
    Note:
    serverAddress is the address of the 3CX server (Version 10)
    phoneIP is the IP address of the remote phone (3CX Phone - iPhone version)
    14:47:28.796 [CM502001]: Source info: From: "Mike"<sip:602@serverAddress>;tag=zwAUfLXHJkc0E.KP-W9wbBG5uYZlpaUW<sip:502@serverAddress>
    14:47:28.796 [CM503013]: Call(48): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 502@serverAddress:5060 tid=PjHXbBF0bDOb3xR4JvF-1-f.lvQFlCC1Av cseq=INVITE contact=602@phoneIP:5060 / 1439 from(wire)
    14:47:28.609 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:502@serverAddress:5060 SIP/2.0
    Via: SIP/2.0/UDP phoneIP:5060;rport=5060;branch=z9hG4bKPjabOr.Se8z-rLJ4IJrCVPGovA1UAt1qNB;received=192.168.4.254
    Max-Forwards: 70
    Contact: "Mike"<sip:602@phoneIP:5060>
    To: <sip:502@serverAddress>
    Call-ID: fE9ot3ZQucyBpx-ePTJDHLAvF.vqs5c0
    CSeq: 1438 INVITE
    Session-Expires: 1800
    Min-SE: 90
    Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
    Supported: replaces, 100rel, timer, norefersub
    User-Agent: 3CXPhone for iPhone 1.0.23
    Content-Length: 0
    14:47:28.609 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 502@serverAddress:5060 tid=PjabOr.Se8z-rLJ4IJrCVPGovA1UAt1qNB cseq=INVITE contact=602@phoneIP:5060 / 1438 from(wire)
    14:47:23.015 [CM504001]: Ext.602: new contact is registered. Contact(s): [sip:602@phoneIP:5060/602]
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, if you use the IPhone on the local network via Wifi does it work ok?
  3. leejor
    11,277
    360
    Are you sending to an IP or a URL ( the serveraddress) ? If a URL, then that must be entered as the SIP Domain in 3CX.
  4. mantalope
    Mar 10, 2011
    35
    iPhone works fine on the local network via WiFi. Only when connecting via "External Server" do I have a problem.
    The server address is a URL (FQDN) and has been set in 3CX in the Settings | Network | Public IP. Is there another place to set it?
  5. mantalope
    Mar 10, 2011
    35
    I found and changed the server address setting under Settings | Advanced | Advanced Tab | Settings for Direct SIP Calls | Local SIP Domain and the remote extensions were able to make calls.
    I do still have a problem where the audio is not coming through. I have the extension option "PBX Delivers Audio" checked, but I am receiving a "No RTP packets were received" message in the log.
    This sounds like it may be a firewall issue.
