Remote Extension with a Snom M3 phone
Discussion in '3CX Phone System - General' started by DrunknMONK, May 11, 2010.
  1. DrunknMONK
    May 10, 2010
    8
    Hi is it possible to set up a snom m3 phone as an extension, the 3cx kit is at work and the snom m3 is at home, if so can you give me easy follow details as i'm new to 3cx/voip
    Gary
  2. vpaulo
    Jun 24, 2009
    23
    see manual`s :)
    create new extension and configure your snom m3 phone. It`s easy.
  3. DrunknMONK
    May 10, 2010
    8
    thanks for the help, you sound like you work for the government full of useless information :lol:
    some actual help would be good.
    Gary
  4. DrunknMONK
    May 10, 2010
    8
    Hi does anyone know if there is any way of making a remote extension with a voip phone not a soft phone
    Thanks Gary
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    In case if http://www.3cx.com/blog/voip-howto/snom-370-remote-extension/
    doesn't help to configure M3 then
    You can try to use this software to connect phone from remote location
    http://www.3cx.com/blog/releases/sip-proxy-manager/
