Remote Extension - Yealink T46G
Discussion in '3CX Phone System - General' started by caiotoledo, Jan 27, 2014.
  1. caiotoledo
    Jan 15, 2014
    19
    Good Morning,
    I'm having some problems with Yealink T46G with 3CX Phone System.
    I put that IP phone with a remote extension, at first he registed and making and receiving calls.
    But when he makes a call, the call stands for exactly 30 seconds, all the times. That doesn't happen when he receive a call.
    I used wireshark to see what's going on, and i saw which the my PBX send a "OK SDP" and the Yealink don't respond, then after some tries my 3CX send a "BYE" and he respond, then the call it's finished.
    Anyone had this problem?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    Usually a firewall is getting in the way.
    Make certain that you have Rport on the Yealink enabled, you may also want to shorten the keep alive interval to 15 seconds or so and you might also consider, if possible, port forwarding at the remote site to the phone. It sounds like the UDP stream is being shutdown and then the system timeouts and disconnects.
    Without knowing more about how it is set-up (STUN, no STUN) etc., this is just a quick guess.
  3. caiotoledo
    Jan 15, 2014
    19
    I followed this tutorial: http://www.3cx.com/blog/voip-howto/remote-extensions/
    With this tutorial i set on Accounts:
    Basic:
    SIP Server: (Public IP)
    SIP Server Port: 5060
    NAT Traversal: STUN
    STUN Server: (Public IP)
    STUN Server Port: 5060
    Advanced:
    UDP Keep-Alive Message: Enabled
    UDP Keep-Alive Interval: 15 (seconds)
    RPort: Enabled
    And i fowarded already some ports on the router to the Phone: 5060, 9000-9049 and 5090 (But we don't use the Tunnel port).
    In the section "Phones" on my Managment Console i saw this remote extension using the port "5162", but i already set the "Sip Local Port" as "5060".
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    You say you set up the router to forward to the phone. If the phone is open the remote side - there is no need to forward firewall ports to the phone. This all needs to be done on the server side.
  5. leejor
    11,126
    330
    Did you actually put the address/URL of a STUN server in here?
  6. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,621
    244
    Also, make sure SIP ALG is turned off.
  7. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Did you make sure the 3CX firewall checker passes?
  8. caiotoledo
    Jan 15, 2014
    19
    All configurations on my 3CX Phone System are ok. Because we already use remote extensions, my director has a IP Phone on his house and works very well (It's a GXP 1400).
    About the STUN Server, yes i put our Public IP on there. And all of my firewal checkers were pass.
    The SIP ALG was not disable on the router. I will do that and post if it's work well.
    Thanks for all help.
  9. caiotoledo
    Jan 15, 2014
    19
    I found the problem.
    My NAT Transversal wasn't using UDP, it was using TCP, that's why all the problems.
    I didn't need to disable the SIP ALG.
    Thanks guys !
