remote extension
Discussion in '3CX Phone System - General' started by last, Sep 4, 2010.
  1. last
    Sep 4, 2010
    hi guys! Could I ask for your help with 3cx, I have forwarded port 5060 udp to my local pbx server adn same 5060 and 5090
    to the local server for pbx, and I did forward port 10001-20000 plus port 9001 to 9499.
    If I chose the the tunnel its not connectng, actuall it say tunnel connection established then it says immediately, Translation file OK
    Attempting to connect 80.72.101.242
    Tunnel got as listening port 4010
    Tunnel got as local SIP port 4011
    Phone got as local port 4012
    Integration with 3CX Call Assistant is OFF
    First port in range should not be even, setting to 10002
    Too many RTP ports in range, setting to default 200
    RTP engine OK
    SIP engine OK
    Sound mic device OK [{BD6DD71B-3DEB-11D1-B171-00C04FC20000}]
    Sound ring device OK [{BD6DD71A-3DEB-11D1-B171-00C04FC20000}]
    Sound play device OK [{BD6DD71A-3DEB-11D1-B171-00C04FC20000}]
    Attempting to start the tunnel
    Tunnel required cfg file:D:\Documents and Settings\owner\Local Settings\Application Data\3CX VoIP Phone\3CxVoipPhone.ini
    Tunnel logfile output:D:\Documents and Settings\owner\Local Settings\Application Data\3CX VoIP Phone\Logs
    Tunnel logging: off
    Tunnel connection created OK
    Tunnel started
    No video webcam selected for video transmission
    Tunnel is attempting to connect remote end 123456 [80.72.101.242:5090]
    Tunnel connection established
    Tunnel send from phone to PBX: REGISTER
    Tunnel has been disconnected by remote end
    Phone is no longer connected
    then it continues saying that for ever.
    what rtp port should i put on the softphone advanced setup what range?
    Do you think there is something I should do then. please help if you can, I want to connect to my office from home but at home there is no router on security thing only my latptop.
    I take this opportunity to ask again could it work fine with my connection if 312kbps?
    thank you
