Remote Office Connectivity
Discussion in '3CX Phone System - General' started by rascott757, Jan 15, 2007.
  1. rascott757
    Jan 13, 2007
    9
    Once I have the PBX set up on this end, what will I need to have a remote office (extension) dial in and register with the PBX over the internet?
  2. Watashi_FR
    Dec 5, 2006
    63
    You need to configure your routers (on-site and at the remote site) for either VPN or NAT to allow remote clients to register with your 3CX server. Ports required are 5060UDP, 7000-7500UDP and 9000-9003TCP (depending on the number of VoIP lines you are supporting). If you have a VPN set up between the two offices, there is no need for NAT configuration, given that your VPN is IP level 3 transparent.
  3. rascott757
    Jan 13, 2007
    9
    Thanks!
    I will give that a shot.
  4. Andrew L
    Feb 13, 2008
    How did your remote office work. I opened up the ports and this method did not work. I got the VPN method to work.
    The VPN is not a very good solution for me. My client needs to be able to give each sales rep a phone pre-configured. He does not want me to have to setup VPN at each location.
