Remote phone can make calls, but not receive.
Discussion in '3CX Phone System - General' started by DavidK, Apr 28, 2011.
  1. DavidK
    Apr 5, 2009
    12
    I'm trying to setup a Grandstream GXP-2000 at a remote location (home office).
    I can get the phone to register on the PBX, make calls outside and to other internal extensions.
    But when you dial in, and try to call that extension directly with #xxx or as part of a ring group it does not receive the call.
    The phone system is running 3CX Phone System v9.0.13545.594 SP.5a
    Thanks,
    David
  2. smb1
    smb1 New Member
    Mar 18, 2009
    104
    First if you have not already, have a look at:
    http://www.3cx.com/blog/voip-howto/remote-extensions/
    If you are still stuck, perhaps you could set system logging to verbose in the system settings and post the resulting logs here with any external IP addressess and/or telephone numbers removed or "xxxxxxx"ed out showing the activity when a call is being initiated.
  3. DavidK
    Apr 5, 2009
    12
    David,
    Thanks, that worked.
    I searched for the problems before, and nothing came up.
    Do you have an Amazon wish list?, I could get something for you to say thanks.
    Thanks again,
    David
  4. willow
    willow Member
    Mar 1, 2011
    471
    Sounds like you may need to port forward port 5060 on the remote end to the phone ip address. Can internal extensions call the remote phone as well or no?
  5. DavidK
    Apr 5, 2009
    12
    Did the exact steps in the blog link, and it worked.
    David
