Remote Phone having trouble making call
Discussion in '3CX Phone System - General' started by craigreilly, Aug 15, 2012.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,069
    201
    I plan on doing a remote session with this user later, to see if something is wrong in the phone settings. But maybe someone can shed some light. I see that no digits are coming across in the log. But user says they dial the digits then DIAL. Extension is using an Asastra 6753i (I know not officially supported but Templates are available to download in v11)
  2. craigreilly
    Feb 1, 2012
    3,069
    201
    By the way, I have another site using the same setup without issue, so I am guessing it might be a Firewall Issue/DSL Router at the remote site from the local TelCo.
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    What I don't see is the destination:
    Contact: "4929"<sip:4929@76.x.x.44:5196;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-1000-8000-00085D18DDFA>"
    To: <sip:66.x.x.112:5060;user=phone>
    From: "4929"<sip:4929@66.x.x.112:5060>;tag=0e4dcfdc10
    Where are they really trying to get to?
  4. craigreilly
    Feb 1, 2012
    3,069
    201
    He says he is dialing his cell phone a 480xxxxx87
    Now, as a test I tried changing 'PBX Delivers Audio' and I see 3 of the digits he is dialing - 480.
    So that leads me to a firewall issue, since I have another Aastra using a different router (Netgear N300) working just fine in a test environment.
  5. lneblett
    Sep 7, 2010
    2,064
    58
    So, he is dialing from external extension 4929 trying to be routed out to so that he can reach an external number 480XXXXXXX; can he reach an internal extension?
  6. craigreilly
    Feb 1, 2012
    3,069
    201
    Another DOH! Moment. :shock:
    For some reason I set the registration under Global SIP instead of Line 1. I may have been in a hurry the day I set it up and put it in the wrong place. So when he tried to make a call, no line was being used... I don't really understand how the Aastras work. How the Global vs Line 1-6 works. On the Yealinks it is just Account 1, Account 2, etc.
  7. craigreilly
    Feb 1, 2012
    3,069
    201
    Oh and if I had used the template no problem. It puts the info into Line 1 automatically. But I programmed it manually because 3cx doesn't support remote registration for that handset.
