Remote Phone
Discussion in 'Windows' started by tobiastromm, Jul 26, 2010.
  1. tobiastromm
    tobiastromm New Member
    Jun 26, 2010
    138
    Hi.
    I have the 3CX Server on my Home and it is working fine.
    I have a second home and I want to connect to the 3CX Server to use the same PSTN line.
    Where 3CX Server is instaled I have Windows 2003 Server with Isa Server 2006. The Isa Server is configured to be a VPN Server.
    I can connect to the VPN Server but when I make a call the audio it failed; or there is no audio in both directions.
    This occurs because I'm using the Isa Server as a VPN Server?
    If I use this VPN server, my problem stop?
    D-Link DI804HV http://support.dlink.com/emulators/di804hv/hwiz.htm
    That http://www.3cx.com/blog/releases/sip-proxy-manager/ can help me?
    I'm using Bria Professional as a softphone.
    11,117
    329
    Have you opened/forwarded all of the necessary ports on your router/firewall. This gives you a list of all of the ports. http://www.3cx.com/blog/voip-howto/linksys-router-configuration/
    The remote end shouldn't require any port forwarding, but, you can end up with problems depending on the type of router used. firewall, or conflicts with another SIP device being used at that location.
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Microsoft ISA server is probably the single biggest problem for SIP. I don't think I have ever seen a successful deployment so long as it was in the mix.
  4. tobiastromm
    Jun 26, 2010
    138
    Right,
    but I'm using VPN. I need to open these ports on my modem anyway?
    On Isa Server this ports are opened.
  5. leejor
    11,117
    329
    Sorry, missed the VPN part. No, using VPN you are essentially on the same network. In that case, it may have something to do with the ISA server as suggested by Kerry. Obviously something is intercepting/blocking voice packets.
  6. tobiastromm
    Jun 26, 2010
    138
    So, 3CX use these ports:
    UDP:7000-7499 Default Range of ports for RTP Media Exchange with devices on the LAN (typically internal extensions, gateways, tunneled connections)
    correct?
  7. leejor
    11,117
    329
    Yes, the internal sets , or those over VPN, should use those. Here's a complete list of ports used on the system. http://www.3cx.com/blog/docs/ports-used/
  8. tobiastromm
    Jun 26, 2010
    138
    The H.323 filter can be the probblem?
  9. FBW
    FBW New Member
    Nov 19, 2008
    108
    You can safely assume that it will never work over ISA server.
    It will not allow you to do NAT properly but instead always change the ports. So you can basically give up on that.
  10. tobiastromm
    Jun 26, 2010
    138
    I will try to install on a machine without Isa Server and with VPN...
    I will report.
  11. tobiastromm
    Jun 26, 2010
    138
    What firewall can I use that works with VoIP?
  12. tobiastromm
    Jun 26, 2010
    138
    I can use Microsoft Forefront Threat Management Gateway 2010???
    http://www.microsoft.com/forefront/threat-management-gateway/en/us/features.aspx
    Enhanced Voice over IP support :
    Forefront TMG includes SIP traversal, enabling simpler deployment of Voice over IP within the network.
  13. FBW
    FBW New Member
    Nov 19, 2008
    108
    Are you looking for a software based solution or wouldn't you mind buying a hardware device?
  14. tobiastromm
    Jun 26, 2010
    138
    Hi...
    Now the correct expression:
    Can I use Microsoft TMG?
    Software based...
  15. FBW
    FBW New Member
    Nov 19, 2008
    108
    Honeslty we have no experience with MS TMG. Looking at the specs on the MS site it might work.
    Maybe it would be a good time to open a ticket at 3CX Support for this although I'm not sure they support this.
  16. tobiastromm
    Jun 26, 2010
    138
    I install 3CX version 6 in a old machine and configure the VPN.
    Work's fine!
    So, Isa Server is the problem...
