Remote to Server to other Remote
Discussion in '3CX Phone System - General' started by michzone, Jan 16, 2013.
  1. michzone
    Jan 30, 2012
    9
    In final testing phases and hit a snag.
    Does anyone know if the 3CX phone system is capable of a remote phone calling another remote phone with no errors?
    Ill put the not sure if its important parts in ()
    Situation
    remote phone (on cable modem)
    to another
    remote phone (on DSL)
    = No audio, yet it rings..
    Remote phones (on cable modem or DSL)
    to main system
    with phone (cable modem)
    All phones works good for the most part other than about a 10 second delay before audio flows.
    Any advice would be great!!
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Sounds like firewall issues. Try a PBX delivers audio ON for your remote extensions.
  3. michzone
    Jan 30, 2012
    9
    Thanks for the reply. not sure what router on the hop has the firewall issue.
    remote phone 1 to server has worked good (cable to cable).
    It seams to be when we tried the new remote phone at the dsl location.
    So I'll start at the dsl router.
    Thanks again.
  4. leejor
    10,368
    229
    Be sure that you don't have a port conflict (previously installed VoIP device using the same port), at the DSL location. Remote locations, with a single device, generally, don't require any special port forwarding to be set-up. Also check the 3CX log to see what IP and port the device is registering with, it should show the public IP, along with the port.
