Remote Voicemail access Extension not recognized
Discussion in '3CX Phone System - General' started by double8pex, Sep 8, 2010.
  1. double8pex
    Jun 8, 2010
    13
    I've setup our Auto Attendant for option 9 to connect to the Voicemail system at extension 9999. I'm able to access the AA and press option 9 and get transferred to the voicemail system.
    The problem is, when it prompts me for the extension number - it does NOT recognize the extension. I tried different extensions and same result. After 3 tries, the call disconnects.
    Any ideas?
    Our setup:
    - 3CX v8
    - 4 digit extensions (extensions start with 9; ex 9xxx)
    - VM extension at 9999
    - AA extension at 8000
    We're setting this up so our users can access vm remotely.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Did you install this as a 4 digit extension or did you change from 3 to 4 digit? I have seen this happen when a 3 digit is upgraded to 4 digit extensions
  3. abc123
    Nov 9, 2009
    712
    I also saw this in the V9 forum (are you running 8 or 9 - i would upgrade to v9 sp2 if i was you and it will fix it)
    Or read 3Cx's manual fix here
    http://www.3cx.com/forums/bug-accessing-another-s-voicemail-box-16599.html#p85128
  4. double8pex
    Jun 8, 2010
    13
    It was originally setup with 4 digit extensions.
    ABC's redirect post to MichaelB's fix worked for us:
    "Go to the LoginVmail.vxml file located in the IVR directory inside the http directory (c:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\ivr) contains the following:
    <field name="ext_number_field">
    <grammar>#|[0-9|*]{3-3}</grammar>
    and changed this to:
    <grammar>#|[0-9|*]{4}</grammar>
    Thanks everyone!
