Remote Yealink Phonebook with 3CX
Discussion in '3CX Phone System - General' started by Ramon1227, Mar 7, 2018.
  1. Ramon1227
    Mar 7, 2018
    Hey,
    I've been trying to figure out a way to build a remote phonebook for our Yealink phones. But every guide or walkthrough I've read even from YeaStar only gives guides for FreePBX. Has anyone had any luck doing anything of this sort? Would be a huge help to me!
    Thanks in advance,
    Ramon
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
  3. Ramon1227
    Mar 7, 2018
    Using 3CX would be cool. But I cant get it to come up on the yealink? When I have been able to through LDAP I have to search for each contact? It doesn't just display them.. Very frustrating.
