Remotely USE of myphone
Discussion in '3CX Phone System - General' started by d.pallotta, Jul 25, 2011.
  1. d.pallotta
    Jul 25, 2011
    With the new Myphone Silverligth Application, is it possibile to remotely connect to pbx via HTTP???
    I noticed that the myphone silverligth application always refers to the IP/HOSTNAME of the local machine
    (i.e. "C:\Program Files\Microsoft Silverlight\sllauncher.exe" 1859439592.pbxhostname").
    Is there a way to use the myphone application remotely from the internet without being in a VPN tunnel???
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    yes, we have done this for a few customers, from your remote location open the below URL from Internet explorer.
    http://Remote-IP-OF-3CX:5000/MyPhone
    you will then be asked for the extension number and pin like normal, you can then use the option to install locally on the remote PC.
  3. whitewhite
    Jul 11, 2011
    20
    Hi davidbenwell,
    Do you know if remote user can install desktop component? it seems unstable connection to me. According to the security log, some traffic are blocked. Do you know the port ranges?
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    MyPhone only uses port 5000. I work remotely and have desktop components installed and everything seems to be working fine.
