removal or 61 from called id in australia
Discussion in '3CX Phone System - General' started by nathanmsaunders, Mar 7, 2017.
  1. nathanmsaunders
    Aug 21, 2016
    32
    Hi Guys,
    we currenty use 3CX in house and are having issues with when users are calling in the phone system is showing the number with a 61 infront of it, is there anyway to remove this.
    for local and mobile calls its coming in as 61 0000 0000.
    is there anyway to fix this.
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
  3. nathanmsaunders
    Aug 21, 2016
    32
    ive had a look an added the CID formatting however it still doesnt seem to work. are you able to provide a screenshot of how you would remove the 61 from the inbound CID and replace it with a 0.
  4. eagle2
    Apr 27, 2011
    1,085
    11
    on inbound settings for your SIP trunk you need to replace the string
    61(.*)
    with string
    0\1
    that's all
    eventually also:
    +61(.*)
    with
    0\1
