Remove non-extensions from keypad view
Discussion in 'Windows' started by jvivona, May 1, 2017.
  1. jvivona
    May 18, 2014
    22
    7
    At the top of the keypad view in the v15 it shows a list of extensions, ring groups, IVRs, call queues, etc. Is there any way to remove anything that isn't an extension? There's no reason for our users to dial an IVR or a call queue.
  2. Meslair
    Oct 19, 2015
    I agree 100%, I don't understand why a user/extension needs to see ring groups, IVR's and such. It makes a marginal user very confused and dangerous. Bad new is you can't even hide the special extensions like you can with a standard user. I did reach out to support and was told very directly....."nope. that's just the way it is". Please allow us to turn this "feature" off asap
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    If you want this behaviour to change or an option to be added so these extension can be excluded from the company phonebook then please post this as a feature request to the ideas section of the forum where it can be upvoted and reviewed by the appropriate department.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,970
    183
    I agree partially with this - it needs to be customized. Maybe at the individual IVR level and Queue level. Companies use Queues and Ring Groups for support of their own employees. Those I would want to show there.
