Remove Phone Provisioning Template
Discussion in '3CX Phone System - General' started by Barnhart, Apr 8, 2015.
  1. Barnhart
    Apr 8, 2015
    I have multiple templates for our T46 Yealink phones, They are all named the same within the 3cx management web interface.
    How do I delete all but one template?
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    When you create a new template you need to modify the "model" inside of the template for the phone type. For example if your doing a template for yealink t48's you would modify this:
    <models>
    <model ua="SIP-T46G">Yealink T46</model>
    <model ua="SIP-T48G">Yealink T48</model>
    </models>
    to be something like
    <models>
    <model ua="SIP-T46G">Yealink T46 - custom1</model>
    <model ua="SIP-T48G">Yealink T48 - custom1</model>
    </models>
    Then when you provision phones you will see your custom template with a different name. Name the actual file something that makes sense to you, then you can add/delete files as you need.
