remove ring group name from the callerid
Discussion in '3CX Phone System - General' started by 88ToM, Mar 7, 2016.
  1. 88ToM
    Feb 17, 2016
    hi, i've the v14 sp3 with a ring group, i don't know how to remove the ring group name from the caller id of the incoming call, thank to all.. in the 12.5 i think it was in the global settings, but now i can't find it.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    51
    You can find it in:
    Settings > Company Phonebook > Phonebook Options – Inbound name to Caller ID
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    I believe the setting you are looking for is under Settings -> Company Phonebook -> "Phonebook settings" button.
  4. 88ToM
    Feb 17, 2016
    It works.. Thanks!!
