Remove voicemail entries when extension vm disabled
Discussion in 'Ideas' started by Bas Gubbels, Jan 14, 2019.
Remove voicemail entries when extension vm disabled 5 5 4votes
5/5, 4 votes
  1. Bas Gubbels
    Oct 23, 2018
    6
    Remove the extensions voicemail entry from the webclient when the voicemail is disabled for that extension.
    This creates a lot of clutter when trasferring calls etc.
  2. vizualpro
    vizualpro New Member
    Jul 9, 2016
    128
    24
    +1 - I also have idea submitted to remove the "Divert to Voicemail" button on softphone for users that have a disabled voicemail.
