Removed FXS Device - System Extensions Remain..
Discussion in '3CX Phone System - General' started by pact, Jul 11, 2016.
  1. pact
    pact New Member
    Dec 16, 2009
    219
    41
    After we upgraded to V15RC2 I cleaned up some of the older Gateways we had configured.
    After removing the FXS devices 3CX has kept the System Extensions and now considers them unregistered.
    Code:
    Unregistered	10001
    Unregistered	10002
    Unregistered	10003
    There is no way to delete them, so I would call this a bug :)
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Can you provide us with more information. Gateways should not be listed in System Extensions Page. Can you send me a pm to see this live?
  3. pact
    pact New Member
    Dec 16, 2009
    219
    41
    Sure, PM incoming :)
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Thanks Pact for this we will check and let you know.
    Thanks again for reporting.
  5. hardtech1
    Feb 17, 2011
    I have the same problem with v15 update5 after I have remove a Patton 2 BRI gateway. I have a 10001 system extension not registered.
    thanks
