Removing file from repository
Discussion in '3CX Phone System - General' started by DavidK, Aug 7, 2010.
  1. DavidK
    Apr 5, 2009
    12
    There is an old .MP3 that seems to be stuck in the repository, and playing randomly. Even thought it is not selected.
    I see it on the repository file list, and would like to delete it permanently.
    I've searched on the support here, and can't find a way to edit the list to get rid of that .MP3.
    Thanks,
    David
  2. KvChaos
    Sep 24, 2010
    I second this notion, since upload the same file doesn't seem to replace the existing one.
