Removing the paging beep without removing it from other areas. (voicemail)
Discussion in '3CX Phone System - General' started by AustinM95, Apr 14, 2018.
  1. AustinM95
    Sep 16, 2017
    6
    I'd like to remove the beep that precedes a page. However, when I modify that the beep.wav file in the system prompts it also affects the beep you hear before leaving a voicemail. Is there a solution to remove one without affecting the other?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    The beep that you hear when paging is not normally being generated by the system, but rather by the phone. Depending on how doing a page, page group, multi-cast, etc., it is inefficient to expect the PBX to send an INVITE page to each phone, and then upon seeing the response from each, to then send an audio wav file beep to each again. Take a look at the phone interface and see.
    As an example, Grandstream phones have a section for each account to set-up intercom settings and their case, they have a setting - "Play warning tone for Auto Answer Intercom"
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,609
    243
    I haven't checked in SP4 but there is a beep generated by 3CX when used as a paging group (hence his question). Removing the beep.wav or replacing it with silence does solve the issue but that same sound is referenced for other things (like VM beep). You'll need to make this a feature request in the ideas section.
  4. AustinM95
    Sep 16, 2017
    6
    I should have mentioned we're using Yealink phones.
    When doing a multi-cast page, you will hear two beeps from the phone (this is generated by the Yealink).
    However, when I modify the beep.wav file (make it silent) in the 3CX console, restart services and try a page using a paging group(not multi-cast) the beep is silent with no re-provisioning of the phones after the changes. This leads me to believe that the PBX is in fact sending the beep tone to each phone.
  5. lneblett
    Sep 7, 2010
    2,086
    65
    I will see what I can do to test when in the office later, but the above is the same setting for Yealink. Is it possible that more than one account is set, which may explain the two beeps?
