Removing the Zero
Discussion in '3CX Phone System - General' started by iperez_genius, Jul 22, 2008.
  1. iperez_genius
    Jul 1, 2008
    56
    is there anyway that if someone get sent to voicemail when he/she finishes recording they can just hangup...and dont need to push zero at the end?
    Ilan
  2. iperez_genius
    Jul 1, 2008
    56
    gradnstream 4104
  3. iperez_genius
    Jul 1, 2008
    56
    i can tell you that if you leave a message 2 minutes long eventaully the 3CX system autosaves the message and ends the call...
    so i suppose there is a hardcoded setting limiting the call length and also allowing for the optional zero...
    i just think that we wont have access to it...
    which is going to be a problem for me ...
    anyways thoughts anyone?
    Ilan
  4. iperez_genius
    Jul 1, 2008
    56
    the only value i found that might help is
    ivrTimeout in the 3cxphonesystem.ini
    but i changed that value from 30000 to 400000 and it didn't seem to make a difference.
    Ilan
