RENAME and extension group?
Discussion in '3CX Phone System - General' started by millsey, Oct 24, 2012.
  1. millsey
    millsey New Member
    Dec 21, 2011
    203
    I cannot find a way to rename an extension group, can anyone point me to how to do it?
    Millsey
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    Sorry, but renaming an extension group does not seem to be allowed. It seems the easiest way is to create your new group, assign the extensions and then delete the old group....if needed.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    The other way is backuping the PBX configuration, modifying the .xml file and restoring it. Be careful.
    Regards
