Rename SIP Trunk
Discussion in '3CX Phone System - General' started by Chris Williams, Sep 11, 2017.
  1. Chris Williams
    Jun 6, 2017
    I'm trying to rename a SIP trunk and getting a message "Given name not unique". I am trying to name it the same as another trunk. My understanding is that we should be able to rename a trunk. I am running V15 Standard which was upgrade around 6 months ago from V10 free.
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    You should be able to rename a trunk (in v.15 / 15.5), but each trunk should have unique name obviously, this is a way to distinguish between trunks, beside they should have unique authentication id (main trunk number).
    YiannisH_3CX likes this.
  3. Chris Williams
    Jun 6, 2017
    My apologies (i'm new to this)...it looks like they are actually gateways...what I am trying to accomplish is having 4 "lines" named the same for outbound call purposes...to be able to have 4 sim calls on that gateway.
  4. sip.bg
    Nov 7, 2016
    704
    219
    If your gateways have different addresses (they are different hosts) they need to have different names and main trunk numbers. If this is one multi-channel / multi-port gateway, you can create it as a custom gateway and handle outgoing call routing inside the gateway (most of them will allow). If you have several physical gateways you can handle outbound rules in 3CX -- up to 5 priorities supported per rule.
  5. leejor
    10,754
    286
    What type (make/model), gateway(s) are you using?
