Renaming an Extension - Webmeeting doesnt change
Discussion in '3CX Phone System - General' started by Russ_Solentive, Jan 29, 2018.
  1. Russ_Solentive
    Jan 29, 2018
    I've re-purposed an old extension of a user that has left however when the new user attempts to do a webmeeting, the old user name is shown. How and where do I update this?
    Thanks,
    Russ
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Russ_Solentive
    What version PBX are you using? You can see the exact build number on the Dashboard under the information column. Also was the extension deleted an d recreated or did you just rename the extension?
  3. Russ_Solentive
    Jan 29, 2018
    Hi @YiannisH_3CX ,
    I believe we are using 15.5.0. The extension was renamed, not deleted and re-created.
  4. YiannisH_3CX
    May 10, 2016
    6,016
    421
    I will need a few details to be able to further troubleshoot your issue. I will send you a p.m. with details so keep an eye on your inbox.
